Ir para o conteúdo principal
ASUS PadFone X Power and Volume Buttons Replacement
O que você precisa
  1. ASUS PadFone X Power and Volume Buttons Replacement, Power and Volume Buttons: passo 1, imagem 1 %32
    • Pry off the back cover with the blue plastic opening tool.
    • Removing the cover may require a bit of force.
  2. ASUS PadFone X Power and Volume Buttons Replacement: passo 2, imagem 1 %32
    • Remove thirteen 3.6mm screws using the T5 Torx Screwdriver.
  3. ASUS PadFone X Power and Volume Buttons Replacement: passo 3, imagem 1 %32
    • Once the screws are removed, the mid-frame can be lifted off of the phone.
  4. ASUS PadFone X Power and Volume Buttons Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Grasp the button strip with tweezers.
    • Pull the buttons upwards gently. The buttons should remove easily.
  5. ASUS PadFone X Power and Volume Buttons Replacement: passo 5, imagem 1 %32
    • Use the blue plastic opening tool to disconnect the orange sensor strip.
    • Applying too much force may damage the connector.
  6. ASUS PadFone X Power and Volume Buttons Replacement: passo 6, imagem 1 %32
    • Grasp the sensor with the tweezers.
    • Pull outwards away from the phone.
    • The sensor is held on by adhesive. You will need to apply some force when removing.
Conclusão
Madeline Dement
Membro desde: 01/24/17
114 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-1, Baechle Spring 2017 Membro de IUPUI, Team 2-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G1
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 274
