Ir para o conteúdo principal
ASUS PadFone X Motherboard Replacement
O que você precisa
  1. ASUS PadFone X Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 ASUS PadFone X Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Motherboard Replacement: passo 2, imagem 1 %32 ASUS PadFone X Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the thirteen 3.6 mm screws using the Torx T5 bit in the screwdriver.
  3. ASUS PadFone X Motherboard Replacement: passo 3, imagem 1 %32 ASUS PadFone X Motherboard Replacement: passo 3, imagem 2 %32
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Motherboard Replacement: passo 4, imagem 1 %32
    • Using the plastic blue plastic opening tool, gently disconnect the battery cable from the motherboard.
    • Applying too much force will damage the connector.
  5. ASUS PadFone X Motherboard Replacement: passo 5, imagem 1 %32 ASUS PadFone X Motherboard Replacement: passo 5, imagem 2 %32
    • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
    • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
  6. ASUS PadFone X Motherboard Replacement: passo 6, imagem 1 %32
    • Using a spudger, pry the vibration motor connector from the motherboard.
  7. ASUS PadFone X Motherboard Replacement: passo 7, imagem 1 %32
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force will damage the conector
  8. ASUS PadFone X Motherboard Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  9. ASUS PadFone X Motherboard Replacement: passo 9, imagem 1 %32 ASUS PadFone X Motherboard Replacement: passo 9, imagem 2 %32
    • Insert the tip of the flat head screwdriver between the panel and the metal clip then gently push down until the clip is slightly bent away from the panel.
    • Do this for all the clips holding the panel down.
    • After all clips are bent away, remove the panel.
  10. ASUS PadFone X Motherboard Replacement: passo 10, imagem 1 %32 ASUS PadFone X Motherboard Replacement: passo 10, imagem 2 %32
    • Disconnect the first connector by prying it upward using the blue plastic opening tool.
    • Disconnect the second connector by first lifting the lock then pulling the connector outward.
  11. ASUS PadFone X Motherboard Replacement: passo 11, imagem 1 %32 ASUS PadFone X Motherboard Replacement: passo 11, imagem 2 %32 ASUS PadFone X Motherboard Replacement: passo 11, imagem 3 %32
    • Insert the tip of the blue plastic opening tool under the motherboard and gently pry upward.
    • Work your way around until the motherboard is free.
  12. ASUS PadFone X Motherboard Replacement: passo 12, imagem 1 %32
    • Flip the motherboard over and locate the front facing camera.
    • Using the tweezers gently remove the black locking mechanism.
    • The black locking mechanism is very fragile and extreme care should be exercised during removal.
  13. ASUS PadFone X Motherboard Replacement: passo 13, imagem 1 %32 ASUS PadFone X Motherboard Replacement: passo 13, imagem 2 %32
    • Use the tweezers to gently pull on the connector to remove the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Ryan
Membro desde: 05/14/12
223 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 8-4, Leahy Fall 2014 Membro de USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
Membros da 4
Autoria de 5 guias
4 comentários
There is a step missing between step 10 and 11, you didn't explain how to remove the flexible connector that go's to the power/volume buttons next to the camera location on the side of the phone.
David Baxter - Responder
which I only had to gently pry up on the connector from the center of the phone out and it came right off.
Hey iFixits,
I have a Padfone S (international version, supposedly the same as the Padfone X sold in the states), which suffered water damage. I presume the logic board needs replacing and since there are more Padfone X's out there, thinking of buying a 'for parts' phone with say, a broken screen, and just swapping logic boards to make one working phone. Does anyone know if these logic boards for the S and X are compatible?? Thanks in advance.
Jack - Responder
I have Asus padfone 2 the phones motherboard is damaged how to use the pad
tushar.modak - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 2,016
