Introdução
This guide is going to show the necessary steps for replacing the Motherboard.
O que você precisa
Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
Work your way around the phone until the entire back cover is loose.
Uma outra pessoa concluiu este guia.
4 comentários
There is a step missing between step 10 and 11, you didn't explain how to remove the flexible connector that go's to the power/volume buttons next to the camera location on the side of the phone.
which I only had to gently pry up on the connector from the center of the phone out and it came right off.
Hey iFixits,
I have a Padfone S (international version, supposedly the same as the Padfone X sold in the states), which suffered water damage. I presume the logic board needs replacing and since there are more Padfone X's out there, thinking of buying a 'for parts' phone with say, a broken screen, and just swapping logic boards to make one working phone. Does anyone know if these logic boards for the S and X are compatible?? Thanks in advance.
I have Asus padfone 2 the phones motherboard is damaged how to use the pad
