Introdução
Need a good selfie? This guide will lead you through replacing your front camera.
O que você precisa
Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
Work your way around the phone until the entire back cover is loose.
Uma outra pessoa concluiu este guia.
