Ir para o conteúdo principal
ASUS PadFone X Battery Replacement
O que você precisa
  1. ASUS PadFone X Battery Replacement, Remove the back panel.: passo 1, imagem 1 %32 ASUS PadFone X Battery Replacement, Remove the back panel.: passo 1, imagem 2 %32
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Battery Replacement, Remove the screws.: passo 2, imagem 1 %32 ASUS PadFone X Battery Replacement, Remove the screws.: passo 2, imagem 2 %32
    • Remove the 13 - 3.6 mm screws using the Torx T5 bit in the screwdriver.
  3. ASUS PadFone X Battery Replacement, Remove the Mid-Frame: passo 3, imagem 1 %32 ASUS PadFone X Battery Replacement, Remove the Mid-Frame: passo 3, imagem 2 %32
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Battery Replacement, Remove the Battery Connector: passo 4, imagem 1 %32 ASUS PadFone X Battery Replacement, Remove the Battery Connector: passo 4, imagem 2 %32
    • Using the blue plastic opening tool, gently disconnect the battery cable from the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Battery Replacement, Remove the battery.: passo 5, imagem 1 %32 ASUS PadFone X Battery Replacement, Remove the battery.: passo 5, imagem 2 %32
    • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
    • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
Conclusão
4 outras pessoas executaram este guia.
John Kue
Membro desde: 10/07/14
379 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 8-4, Leahy Fall 2014 Membro de USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 5,128
