Ir para o conteúdo principal
ASUS N56JR-MH71 Hard Drive Replacement
O que você precisa
  1. ASUS N56JR-MH71 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 ASUS N56JR-MH71 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Push the battery latch.
  2. ASUS N56JR-MH71 Hard Drive Replacement: passo 2, imagem 1 %32
    • Keep the battery latch held while you remove the battery.
  3. ASUS N56JR-MH71 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 ASUS N56JR-MH71 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32 ASUS N56JR-MH71 Hard Drive Replacement, Hard Drive: passo 3, imagem 3 %32
    • Remove the one screw securing the back cover.
    • Pry off the cover using a finger.
    • This device was missing its screws on the back cover when we received the device. As a result, we do not know what head type the screws are, along with their lengths.
  4. ASUS N56JR-MH71 Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the screws securing hard drive to the laptop.
    • Pull out the hard drive from the connector.
    • Replace with a new hard drive.
Conclusão
Ruben Lopez
Membro desde: 11/05/18
399 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team S1-G4, Baechle Fall 2018 Membro de IUPUI, Team S1-G4, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 718
