Introdução
Whether your hard drive died, you need more space, or need faster speeds, this guide will show you how to replace the hard drive in your ASUS N56JN Laptop.
O que você precisa
Pull the switch on the back of laptop in the direction of the arrow.
If done correctly the battery should pop out. Lift the battery to remove it.
To reassemble your device, follow instructions 1-6 in the reverse order.
8 outras pessoas executaram este guia.
2 comentários
That’s not rocket science - How to clone the disk properly? that’s the part I can’t manage… Any freeware clone software that actually WORKS and is not just a dumb backup software…?
The free version of Minitool Partition Wizard is very good.
