Ir para o conteúdo principal
ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement
O que você precisa
  1. ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement, Back Case: passo 1, imagem 1 %32 ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement, Back Case: passo 1, imagem 2 %32
    • Turn the laptop off and unplug all cables.
    • Flip over so the bottom is facing you.
    • Remove the ten 3mm Torx T5 screws from the bottom cover.
  2. ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement: passo 2, imagem 1 %32 ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement: passo 2, imagem 2 %32
    • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
    • Run the spudger along the perimeter of the bottom cover to remove.
  3. ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement, CD/DVD Drive: passo 3, imagem 1 %32 ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement, CD/DVD Drive: passo 3, imagem 2 %32
    • Remove the two 4mm black Phillips #1 screws from the top of the CD/DVD bracket.
    • Remove the single 4mm silver Phillips #1 screw from the bottom of the CD/DVD bracket.
    • Remove the CD/DVD bracket.
  4. ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement: passo 4, imagem 1 %32 ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement: passo 4, imagem 2 %32
    • Remove the single 4mm silver Phillips #1 screw.
  5. ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement: passo 5, imagem 1 %32
    • Slide the drive out of the laptop using both hands.
Conclusão
Steven Hahn
Membro desde: 01/29/18
884 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S5-G1, Passmore Spring 2018 Membro de USF Tampa, Team S5-G1, Passmore Spring 2018
USFT-PASSMORE-S18S5G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,146
