Introdução
This guide will detail how to remove and replace the back case of the device. This will give you access to the inner parts of the laptop.
O que você precisa
Turn the laptop off and unplug all cables.
Flip over so the bottom is facing you.
Remove the ten 3mm Torx T5 screws from the bottom cover.
5 outras pessoas executaram este guia.
