Ir para o conteúdo principal
ASUS MeMo Pad FHD10 Speakers Replacement
O que você precisa
  1. ASUS MeMo Pad FHD10 Speakers Replacement, Battery: passo 1, imagem 1 %32 ASUS MeMo Pad FHD10 Speakers Replacement, Battery: passo 1, imagem 2 %32
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Speakers Replacement: passo 2, imagem 1 %32 ASUS MeMo Pad FHD10 Speakers Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Speakers Replacement: passo 3, imagem 1 %32 ASUS MeMo Pad FHD10 Speakers Replacement: passo 3, imagem 2 %32
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Speakers Replacement: passo 4, imagem 1 %32 ASUS MeMo Pad FHD10 Speakers Replacement: passo 4, imagem 2 %32 ASUS MeMo Pad FHD10 Speakers Replacement: passo 4, imagem 3 %32
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
  5. ASUS MeMo Pad FHD10 Speakers Replacement, Speakers: passo 5, imagem 1 %32
    • Remove three screws using a Phillips #00 screwdriver.
  6. ASUS MeMo Pad FHD10 Speakers Replacement: passo 6, imagem 1 %32
    Comprar
    • The two speakers are located on opposite sides of the device. Both are long black pieces with connections to the motherboard.
    • Unplug the speaker cables from their connections on the motherboard gently by using tweezers.
  7. ASUS MeMo Pad FHD10 Speakers Replacement: passo 7, imagem 1 %32 ASUS MeMo Pad FHD10 Speakers Replacement: passo 7, imagem 2 %32 ASUS MeMo Pad FHD10 Speakers Replacement: passo 7, imagem 3 %32
    • Gently use your hands to remove the speakers.
Conclusão
Al Muatasim
Membro desde: 01/20/15
294 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 9-5, Blackwell Winter 2015 Membro de USF Tampa, Team 9-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 524
