Introdução
If your speakers on ASUS Memo Pad FHD tablet isn't working properly, then you can use this guide to replace the speakers.
O que você precisa
Unplug the charger and remove any memory card you may have in the device.
Wedge the plastic opening tool between the front and back cover on every side.
Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
Once disconnected, remove the back cover from the device screen.
