Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The motherboard has lots of other parts mounted into it, therefore it is important to treat the board carefully, and follow instructions as shown on the steps.
O que você precisa
Unplug the charger and remove any memory card you may have in the device.
Wedge the plastic opening tool between the front and back cover on every side.
Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
Once disconnected, remove the back cover from the device screen.
There should be a total of 12 screws removed from the device, 7 of which have already been removed in the process of taking out the battery and the speakers. The remaining screws are highlighted in blue.
Uma outra pessoa concluiu este guia.
