Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide is for battery’s replacement. The guide follows a step-by-step sequence to take out the back panel, unplug cables and replace the batter. The battery type is 6760mAh Li-polymer with 10 hours battery life.
O que você precisa
Plug out the charger and pull out the memory card if connected as a preliminary step.
Wedge the plastic opening tool between the front and back cover on every side as shown on the photos.
Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
Remove the back cover.
Locate the battery cable attached to the motherboard. Remove the cable gently using tweezers, the same way applied before for the ribbon cables.
Now, you are able to remove the battery from the device. You can then separate the metal frame located at the back of the battery by gently wedging the plastic open tool in between the two parts, and slide it back and forth until the metal frame is removed.
5 outras pessoas executaram este guia.
