Ir para o conteúdo principal
ASUS MeMO Pad 7 (ME572C) Motherboard Replacement
O que você precisa
  1. ASUS MeMO Pad 7 (ME572C) Motherboard Replacement, Rear Panel: passo 1, imagem 1 %32 ASUS MeMO Pad 7 (ME572C) Motherboard Replacement, Rear Panel: passo 1, imagem 2 %32
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 2, imagem 1 %32 ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 2, imagem 2 %32 ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 2, imagem 3 %32
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 3, imagem 1 %32
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
  4. ASUS MeMO Pad 7 (ME572C) Motherboard Replacement, Battery: passo 4, imagem 1 %32 ASUS MeMO Pad 7 (ME572C) Motherboard Replacement, Battery: passo 4, imagem 2 %32 ASUS MeMO Pad 7 (ME572C) Motherboard Replacement, Battery: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Disconnect the ZIF connectors to release the data cables holding the battery in. Use tweezers to do this.
    • You can also use your hand to remove ZIF connectors.
    • ZIF connectors are delicate so be careful when you are removing them.
  5. ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 5, imagem 1 %32
    • Find the place where the battery connector is. Disconnect the battery connectors by carefully pulling up on them using a spudger or plastic opening tool.
  6. ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 6, imagem 1 %32 ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 6, imagem 2 %32 ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 6, imagem 3 %32
    • Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery.
    • The casing of the battery is soft and can easily tear. Tearing can lead to the chemicals in the battery to leak out.
  7. ASUS MeMO Pad 7 (ME572C) Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 ASUS MeMO Pad 7 (ME572C) Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • After removing the battery from the device, locate the volume connectors on the side of the device.
    • Using tweezers, carefully remove the volume connectors and place it to the side.
  8. ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 8, imagem 1 %32 ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 8, imagem 2 %32
    • Locate the GPS antenna. Pry off the GPS antenna cable with a spudger.
  9. ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 9, imagem 1 %32 ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 9, imagem 2 %32
    • Locate seven 2mm Phillips #0 screws attaching the motherboard to the pad. Remove the screws with a Phillips #000 screwdriver.
    • Place your screws somewhere you will remember they are at.
  10. ASUS MeMO Pad 7 (ME572C) Motherboard Replacement: passo 10, imagem 1 %32
    • Once all the screws are taken out, you can remove the motherboard. Carefully, take the motherboard out with a plastic opening tool.
Conclusão
3 outras pessoas executaram este guia.
Tyler Tripp
Membro desde: 08/26/15
395 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 14-23, Meier Fall 2015 Membro de USF Tampa, Team 14-23, Meier Fall 2015
USFT-MEIER-F15S14G23
4 Membros
Autoria de 14 guias
3Comentários do guia
hi, i need the power supply board where the usb in. please let me know where i can buy one. Asus MeMO Pad 7 (ME572C)
i think it called pcb
Feroz YF - Responder
Hello, I have a broken Memo Pad that doesn’t power on anymore. The mainboard seems ok though. If I switch the board of the broken asus to another device, will I then be able to boot the system as it was on the old device?
Pen Guin - Responder
Many thanks to this guide. With the instruction I could repair my dead screen. The yellow/orange screen cable was just a little bit out after a 40 cm drop. Just pushing the battery a little bit in the direction of the motherboard was enough to reconnect the screen … I suspect that the weight of the battery pulled the video cable out of the the connector as the video cable is attached to the battery pack with adhesive tape.
Dekerser Dekkers - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 17
Ao todo: 4,058
