Introdução
This guide will show you how to replace the front camera for a Asus MeMO Pad 7. If you want to take a picture from the front camera but it is not working, you can simply follow the instructions to replace and make it work again.
O que você precisa
Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
Quase terminado!
Conclusão
