Ir para o conteúdo principal
ASUS K53E-BBR1 RAM Replacement
O que você precisa
  1. ASUS K53E-BBR1 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over so you can see the battery.
  2. ASUS K53E-BBR1 RAM Replacement: passo 2, imagem 1 %32
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. ASUS K53E-BBR1 RAM Replacement: passo 3, imagem 1 %32 ASUS K53E-BBR1 RAM Replacement: passo 3, imagem 2 %32 ASUS K53E-BBR1 RAM Replacement: passo 3, imagem 3 %32
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
  4. ASUS K53E-BBR1 RAM Replacement, RAM: passo 4, imagem 1 %32 ASUS K53E-BBR1 RAM Replacement, RAM: passo 4, imagem 2 %32
    • Remove the two 4mm Phillips #0 screws located on the opposite ends of the laptop.
  5. ASUS K53E-BBR1 RAM Replacement: passo 5, imagem 1 %32 ASUS K53E-BBR1 RAM Replacement: passo 5, imagem 2 %32
    • Slide the back panel backwards until it stops.
    • You can now lift the panel up and out of the laptop casing.
  6. ASUS K53E-BBR1 RAM Replacement: passo 6, imagem 1 %32 ASUS K53E-BBR1 RAM Replacement: passo 6, imagem 2 %32 ASUS K53E-BBR1 RAM Replacement: passo 6, imagem 3 %32
    • The RAM is now visible.
    • Remove the RAM by pressing out on both tabs visible on each side of the RAM.
    • To work the tabs, take your finger tips and press outwards from the indents on the RAM.
  7. ASUS K53E-BBR1 RAM Replacement: passo 7, imagem 1 %32 ASUS K53E-BBR1 RAM Replacement: passo 7, imagem 2 %32
    • The RAM is now angled up and you can remove the RAM by pulling it out in the direction it is facing.
    • Gently Pull the RAM out of its connector without pushing down or pulling up.
  8. ASUS K53E-BBR1 RAM Replacement: passo 8, imagem 1 %32 ASUS K53E-BBR1 RAM Replacement: passo 8, imagem 2 %32 ASUS K53E-BBR1 RAM Replacement: passo 8, imagem 3 %32
    • Repeat the previous two steps for the second stick of RAM.
Conclusão
William Colangelo
Membro desde: 03/25/19
121 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S6-G4, Peak Spring 2019 Membro de UMass Dartmouth, Team S6-G4, Peak Spring 2019
UMASSD-PEAK-S19S6G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 200
