Ir para o conteúdo principal
ASUS K53E-BBR1 Keyboard Replacement
O que você precisa
  1. ASUS K53E-BBR1 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Lift the monitor up so that the keyboard is visible.
    • You will notice five spots on the top of the keyboard where the iFixit opening tool should be placed.
  2. ASUS K53E-BBR1 Keyboard Replacement: passo 2, imagem 1 %32 ASUS K53E-BBR1 Keyboard Replacement: passo 2, imagem 2 %32 ASUS K53E-BBR1 Keyboard Replacement: passo 2, imagem 3 %32
    • Use the iFixit opening tool on each of the designated spots to pry the keyboard apart from the palm rest.
    • You will hear a light "pop" sound each time you pry the keyboard.
    • Once the keyboard is loose, do not pull keyboard far (more than 3 inches) apart from the from the palm rest. There is a "bus" connector attached to the bottom.
  3. ASUS K53E-BBR1 Keyboard Replacement: passo 3, imagem 1 %32
    • Carefully disconnect the "bus" connector from the laptop. Press on it with your thumb/index finger and slide it right along the surface of the laptop.
Conclusão
Paulo Fortes
Membro desde: 03/20/19
147 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S6-G4, Peak Spring 2019 Membro de UMass Dartmouth, Team S6-G4, Peak Spring 2019
UMASSD-PEAK-S19S6G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 358
