Ir para o conteúdo principal
ASUS K53E-BBR1 Hard Drive Replacement
O que você precisa
  1. ASUS K53E-BBR1 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over so you can see the battery.
  2. ASUS K53E-BBR1 Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. ASUS K53E-BBR1 Hard Drive Replacement: passo 3, imagem 1 %32 ASUS K53E-BBR1 Hard Drive Replacement: passo 3, imagem 2 %32 ASUS K53E-BBR1 Hard Drive Replacement: passo 3, imagem 3 %32
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
  4. ASUS K53E-BBR1 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 ASUS K53E-BBR1 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Remove the two 4mm Phillips #0 screws on either side of the laptop.
  5. ASUS K53E-BBR1 Hard Drive Replacement: passo 5, imagem 1 %32 ASUS K53E-BBR1 Hard Drive Replacement: passo 5, imagem 2 %32
    • Slide the back panel towards you until it stops.
    • Lift the panel up out of the laptop casing.
  6. ASUS K53E-BBR1 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the four 3mm Phillips #0 screws holding the hard drive in place.
  7. ASUS K53E-BBR1 Hard Drive Replacement: passo 7, imagem 1 %32
    • Disconnect the hard drive from the laptop by sliding it towards the outside edge.
  8. ASUS K53E-BBR1 Hard Drive Replacement: passo 8, imagem 1 %32 ASUS K53E-BBR1 Hard Drive Replacement: passo 8, imagem 2 %32
    • Grab hold of the black cloth tab and pull the hard drive out from the laptop.
Conclusão
Matthew Merlo
Membro desde: 03/20/19
267 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S6-G4, Peak Spring 2019 Membro de UMass Dartmouth, Team S6-G4, Peak Spring 2019
UMASSD-PEAK-S19S6G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 258
