Ir para o conteúdo principal
ASUS K50IJ Screen replacement 15.6" Replacement
O que você precisa
  1. ASUS K50IJ Screen replacement 15.6" Replacement, Battery: passo 1, imagem 1 %32
    • Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
  2. ASUS K50IJ Screen replacement 15.6" Replacement: passo 2, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 2, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 2, imagem 3 %32
    • Lift the exposed lip and remove the battery cover.
  3. ASUS K50IJ Screen replacement 15.6" Replacement: passo 3, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 3, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 3, imagem 3 %32
    • Press the tabs on the battery and lift them. The battery should come out easily.
  4. ASUS K50IJ Screen replacement 15.6" Replacement, Fan: passo 4, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement, Fan: passo 4, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement, Fan: passo 4, imagem 3 %32
    • Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
  5. ASUS K50IJ Screen replacement 15.6" Replacement: passo 5, imagem 1 %32
    • Remove the one .5 mm screw located in the top right corner of the battery compartment.
  6. ASUS K50IJ Screen replacement 15.6" Replacement: passo 6, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 6, imagem 2 %32
    • Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
  7. ASUS K50IJ Screen replacement 15.6" Replacement: passo 7, imagem 1 %32
    • Unplug the wire cable attached to the fan by pulling it out .
  8. ASUS K50IJ Screen replacement 15.6" Replacement: passo 8, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 8, imagem 2 %32
    • Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
    • Lift the fan up with your fingers.
  9. ASUS K50IJ Screen replacement 15.6" Replacement, Charging Port: passo 9, imagem 1 %32
    • Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
  10. ASUS K50IJ Screen replacement 15.6" Replacement: passo 10, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 10, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 10, imagem 3 %32
    • Using the PH1 screwdriver, remove the four .75 mm screws from the copper heat sync. They will be labeled 1-4.
    • Pull the copper heat sync out of the laptop.
  11. ASUS K50IJ Screen replacement 15.6" Replacement: passo 11, imagem 1 %32
    • Using the PH1 screwdriver, remove four .75 mm screws from the driver, located in the bottom-right corner of the laptop.
  12. ASUS K50IJ Screen replacement 15.6" Replacement: passo 12, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 12, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 12, imagem 3 %32
    • Pull on the black tab on the driver to slide the driver back, and lift the driver out of the laptop.
  13. ASUS K50IJ Screen replacement 15.6" Replacement: passo 13, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 13, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 13, imagem 3 %32
    • Using the PH1 screwdriver, remove the five .5 mm screws from the SD card reader, located in the bottom-middle corner of the laptop.
    • Slide the SD card reader away and out.
  14. ASUS K50IJ Screen replacement 15.6" Replacement: passo 14, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 14, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 14, imagem 3 %32
    • Detach the white and black wires from the Wi-Fi card, located in the central area of the laptop.
  15. ASUS K50IJ Screen replacement 15.6" Replacement: passo 15, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 15, imagem 2 %32
    • Using the PH 1 screwdriver, remove the two .25 mm screws from the Wi-Fi card.
  16. ASUS K50IJ Screen replacement 15.6" Replacement: passo 16, imagem 1 %32
    • Slide the Wi-Fi card out of its slot to remove.
  17. ASUS K50IJ Screen replacement 15.6" Replacement: passo 17, imagem 1 %32
    • Using the PH1mm screwdriver, remove one .5 mm screw from the disk drive, located inthe top-right corner of the laptop.
  18. ASUS K50IJ Screen replacement 15.6" Replacement: passo 18, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 18, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 18, imagem 3 %32
    • Slide the disc drive out of its slot.
  19. ASUS K50IJ Screen replacement 15.6" Replacement: passo 19, imagem 1 %32
    • Using the PH 1 screwdriver, remove the two .5 mm screws from the RAM drive.
  20. ASUS K50IJ Screen replacement 15.6" Replacement: passo 20, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 20, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 20, imagem 3 %32
    • Slide and lift the RAMdrive out of its port.
  21. ASUS K50IJ Screen replacement 15.6" Replacement: passo 21, imagem 1 %32
    • Using the PH1 screwdriver, remove the .75 mm screw from the plastic housing corner, located in the bottom-right corner of the laptop.
  22. ASUS K50IJ Screen replacement 15.6" Replacement: passo 22, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 22, imagem 2 %32
    • Unplug the black cable from the central area of the laptop.
  23. ASUS K50IJ Screen replacement 15.6" Replacement: passo 23, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 23, imagem 2 %32
    • Unplug the wire cable in the central area of the laptop.
  24. ASUS K50IJ Screen replacement 15.6" Replacement: passo 24, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 24, imagem 2 %32
    • Unplug the wire and black cables on the motherboard, located in the upper-left corner of the laptop.
  25. ASUS K50IJ Screen replacement 15.6" Replacement: passo 25, imagem 1 %32
    • Using the PH1 screwdriver, unscrew the two .75 mm screws from the top-left corner of the motherboard.
  26. ASUS K50IJ Screen replacement 15.6" Replacement: passo 26, imagem 1 %32
    • Using the PH 1 screwdriver, remove the .75 cm screw from the top-middle section of the motherboard.
  27. ASUS K50IJ Screen replacement 15.6" Replacement: passo 27, imagem 1 %32
    • Using the PH1 screwdriver, remove the .75 mm screw from the top-middle corner of the motherboard.
  28. ASUS K50IJ Screen replacement 15.6" Replacement: passo 28, imagem 1 %32
    • Using the PH1 screwdriver, remove the three .75 mm screws from the bottom corner of the motherboard.
  29. ASUS K50IJ Screen replacement 15.6" Replacement: passo 29, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 29, imagem 2 %32
    • There is a ribbon cable connected to the back of the motherboard. Be careful not to break the ribbon cable.
    • Slide the motherboard to the right and lift it up, but do not pull it completely out.
  30. ASUS K50IJ Screen replacement 15.6" Replacement: passo 30, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 30, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 30, imagem 3 %32
    • Gently unplug the ribbon cable from the underside of the motherboard.
  31. ASUS K50IJ Screen replacement 15.6" Replacement: passo 31, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 31, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 31, imagem 3 %32
    • The ribbon cable that was plugged into the motherboard is attached to the keyboard. Be sure not to damage it.
    • Use the metal spudger or opening tool across the top edge of the keyboard to pop it out.
  32. ASUS K50IJ Screen replacement 15.6" Replacement: passo 32, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 32, imagem 2 %32
    • Use the metal spudger or opening tool to pop out the plastic hinge covers.
  33. ASUS K50IJ Screen replacement 15.6" Replacement: passo 33, imagem 1 %32
    • Use the PH1 screwdriver to remove the .75 mm screws from the hinges. Each hinge has one screw.
  34. ASUS K50IJ Screen replacement 15.6" Replacement: passo 34, imagem 1 %32
    • Be careful not to damage the cables that are attached to the screen frame. Be sure to pull them through the laptop carefully.
    • The screen should separate from the rest of the laptop.
  35. ASUS K50IJ Screen replacement 15.6" Replacement: passo 35, imagem 1 %32
    • Using the PH1 screwdriver, remove the .75 mm screw from the bottom-middle section was previously covering.
  36. ASUS K50IJ Screen replacement 15.6" Replacement: passo 36, imagem 1 %32
    • Using the PH 1 screwdriver, remove the .75 cm screw from the bottom-middle section where the keyboard was previously covering.
  37. ASUS K50IJ Screen replacement 15.6" Replacement: passo 37, imagem 1 %32
    • Lift the front cover off of the laptop.
  38. ASUS K50IJ Screen replacement 15.6" Replacement: passo 38, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 38, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 38, imagem 3 %32
    • Flip the laptop back over. The charging port will be located in the top-right corner.
  39. ASUS K50IJ Screen replacement 15.6" Replacement, Screen replacement 15.6": passo 39, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement, Screen replacement 15.6": passo 39, imagem 2 %32
    • Using a metal spudger, pop off the six rubber screw covers.
  40. ASUS K50IJ Screen replacement 15.6" Replacement: passo 40, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 40, imagem 2 %32
    • Using the PH1mm screwdriver, remove the six .75 mm screws from the front of the screen frame.
  41. ASUS K50IJ Screen replacement 15.6" Replacement: passo 41, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 41, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 41, imagem 3 %32
    • Use the plastic opening tool or spudger along the edge of the frame, to pry off the frame.
  42. ASUS K50IJ Screen replacement 15.6" Replacement: passo 42, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 42, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 42, imagem 3 %32
    • Using the PH1 screwdriver, remove the four bottom .75 mm screws from the screen frame.
  43. ASUS K50IJ Screen replacement 15.6" Replacement: passo 43, imagem 1 %32
    • Using the PH1 screwdriver, remove the two .75 cm screws from the top of the screen frame.
  44. ASUS K50IJ Screen replacement 15.6" Replacement: passo 44, imagem 1 %32
    • Lift the bracket off the top of the screen frame.
  45. ASUS K50IJ Screen replacement 15.6" Replacement: passo 45, imagem 1 %32
    • Lift the screen should out.
Conclusão
Uma outra pessoa concluiu este guia.
3 comentários
Very well done. Thank You
Rc wells - Responder
Thank you for your time!
tatiana.morais.89 - Responder
Now, I don´t know how to connect the cables to the motherboard because they are too short.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 1,157
