Ir para o conteúdo principal
ASUS K43SV SSD Replacement
O que você precisa
  1. ASUS K43SV SSD Replacement, SSD: passo 1, imagem 1 %32
    • Disconnect the ASUS k43sv laptop from the external power supply before starting.
    • Place the laptop on a flat table with its back facing up.
  2. ASUS K43SV SSD Replacement: passo 2, imagem 1 %32
    • Slide the latch on the right side of the battery on the back of the laptop to the right to the unlocked position.
  3. ASUS K43SV SSD Replacement: passo 3, imagem 1 %32 ASUS K43SV SSD Replacement: passo 3, imagem 2 %32 ASUS K43SV SSD Replacement: passo 3, imagem 3 %32
    • With your left hand, slide the latch on the left side of the battery to the left and hold it.
    • With your right hand, slide the battery out of the battery compartment and place the battery away from the laptop.
  4. ASUS K43SV SSD Replacement: passo 4, imagem 1 %32 ASUS K43SV SSD Replacement: passo 4, imagem 2 %32
    • Remove the two screws on the bottom of the laptop using a Phillips #0 screwdriver.
  5. ASUS K43SV SSD Replacement: passo 5, imagem 1 %32 ASUS K43SV SSD Replacement: passo 5, imagem 2 %32 ASUS K43SV SSD Replacement: passo 5, imagem 3 %32
    • Slide the hard disk compartment cover towards you with both hands and remove it from the laptop.
  6. ASUS K43SV SSD Replacement: passo 6, imagem 1 %32 ASUS K43SV SSD Replacement: passo 6, imagem 2 %32 ASUS K43SV SSD Replacement: passo 6, imagem 3 %32
    • Remove the four screws from the hard drive support arm using a Phillips #0 screwdriver.
  7. ASUS K43SV SSD Replacement: passo 7, imagem 1 %32 ASUS K43SV SSD Replacement: passo 7, imagem 2 %32 ASUS K43SV SSD Replacement: passo 7, imagem 3 %32
    • Lift the plastic sheet on the left side of the hard drive slightly by hand.
    • Remove the hard drive and its support from the hard drive compartment.
  8. ASUS K43SV SSD Replacement: passo 8, imagem 1 %32 ASUS K43SV SSD Replacement: passo 8, imagem 2 %32 ASUS K43SV SSD Replacement: passo 8, imagem 3 %32
    • Remove the four screws on the side of the hard disk support using a Phillips #0 screwdriver.
Conclusão
Duanrui Liu
Membro desde: 09/20/21
279 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 154
Últimos 30 dias: 172
Duração total: 1,460
