Ir para o conteúdo principal
ASUS K200MA-DS01T Motherboard Replacement
O que você precisa
  1. ASUS K200MA-DS01T Motherboard  Replacement, Back Panel: passo 1, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement, Back Panel: passo 1, imagem 2 %32
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Motherboard  Replacement: passo 2, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 2, imagem 2 %32
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Motherboard  Replacement: passo 3, imagem 1 %32
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Motherboard  Replacement: passo 4, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 4, imagem 2 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 4, imagem 3 %32
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Motherboard  Replacement, Keyboard: passo 5, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement, Keyboard: passo 5, imagem 2 %32
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Motherboard  Replacement: passo 6, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 6, imagem 2 %32
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Motherboard  Replacement, Track Pad: passo 7, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement, Track Pad: passo 7, imagem 2 %32
    • Lift the keyboard connector from the keyboard.
  8. ASUS K200MA-DS01T Motherboard  Replacement: passo 8, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 8, imagem 2 %32
    • Lift the foil sheet.
  9. ASUS K200MA-DS01T Motherboard  Replacement: passo 9, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 9, imagem 2 %32
    • Eight 3 mm screws using Phillips screwdriver.
    • Be sure to remove the screw underneath the keyboard connector.
  10. ASUS K200MA-DS01T Motherboard  Replacement: passo 10, imagem 1 %32
    • Two 2 mm screws using a Phillips #00 screwdriver.
  11. ASUS K200MA-DS01T Motherboard  Replacement: passo 11, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 11, imagem 2 %32
    • Using a plastic spudger, remove the metal plate.
  12. ASUS K200MA-DS01T Motherboard  Replacement: passo 12, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 12, imagem 2 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 12, imagem 3 %32
    • Flip the keyboard over.
    • Using a plastic spudger, pry the track pad off the plastic piece underneath.
    • Don't be afraid to use some force in this step because the track pad and the plastic piece are glued together.
  13. ASUS K200MA-DS01T Motherboard  Replacement, Battery: passo 13, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement, Battery: passo 13, imagem 2 %32
    • Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
    • Remove the following screws from the middle and far ends of the battery:
    • Three 4mm Phillips screws using a Phillips #0 screwdriver.
    • The battery will be located closest to the screen.
  14. ASUS K200MA-DS01T Motherboard  Replacement: passo 14, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 14, imagem 2 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 14, imagem 3 %32
    • Gripping the wider left section, lift the battery up and away from computer.
  15. ASUS K200MA-DS01T Motherboard  Replacement, Fan: passo 15, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement, Fan: passo 15, imagem 2 %32
    • Locate the fan, two screws and two color coded wires in the bottom left corner of the computer.
  16. ASUS K200MA-DS01T Motherboard  Replacement: passo 16, imagem 1 %32
    • Remove the following screws from the fan:
    • Two 4mm screws using a Phillips #0 screwdriver.
  17. ASUS K200MA-DS01T Motherboard  Replacement: passo 17, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 17, imagem 2 %32
    • Firmly pull colored wires away from wire slot.
  18. ASUS K200MA-DS01T Motherboard  Replacement: passo 18, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 18, imagem 2 %32
    • After removing both the screws and color coded wires, lift fan out of place.
    • Tools such as spudgers or tweezers may be used for fan removal.
  19. ASUS K200MA-DS01T Motherboard  Replacement, Hard drive: passo 19, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement, Hard drive: passo 19, imagem 2 %32
    • Four 4mm Phillips screws using a Phillips #0 screwdriver.
  20. ASUS K200MA-DS01T Motherboard  Replacement: passo 20, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 20, imagem 2 %32
    • Remove by sliding hard driving right and away from the computer using the tag on the right side.
  21. ASUS K200MA-DS01T Motherboard  Replacement, Motherboard: passo 21, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement, Motherboard: passo 21, imagem 2 %32
    • Locate and remove the following screws on the motherboard:
    • Eighteen 4mm Phillips screws using a Phillips #0 screw driver.
  22. ASUS K200MA-DS01T Motherboard  Replacement: passo 22, imagem 1 %32
    • Locate all 4 connectors.
    • One connector will be a ribbon, a second will be color codded, a third will be a single gold cable, and a fourth will be a wide vertically placed connector.
  23. ASUS K200MA-DS01T Motherboard  Replacement: passo 23, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 23, imagem 2 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 23, imagem 3 %32
    • Use the blue ribbon to vertically pull the connector away from the mother board.
    • A firm amount of force will be required.
  24. ASUS K200MA-DS01T Motherboard  Replacement: passo 24, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 24, imagem 2 %32
    • Pull the connector horizontally away from the socket.
  25. ASUS K200MA-DS01T Motherboard  Replacement: passo 25, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 25, imagem 2 %32
    • Lift the latch upwards to release the computer ribbon connector.
  26. ASUS K200MA-DS01T Motherboard  Replacement: passo 26, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 26, imagem 2 %32
    • Horizontally pull the computer ribbon cable away from latch.
  27. ASUS K200MA-DS01T Motherboard  Replacement: passo 27, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 27, imagem 2 %32
    • Vertically pull the cable from the head away from the placement.
  28. ASUS K200MA-DS01T Motherboard  Replacement: passo 28, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 28, imagem 2 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 28, imagem 3 %32
    • Once all screws and connectors are removed, gently lift the motherboard from computer.
    • Removing motherboard does not require firm force.
    • To prevent damage, DO NOT use tools to remove the motherboard.
  29. ASUS K200MA-DS01T Motherboard  Replacement: passo 29, imagem 1 %32 ASUS K200MA-DS01T Motherboard  Replacement: passo 29, imagem 2 %32
    • Remove the final piece of the motherboard on the right-hand side of the keyboard shell.
Conclusão
Terrinda
Membro desde: 09/17/18
526 Reputação
Autoria de 4 guias
Equipe
CSU Fullerton, Team S2-G5, Bruce Fall 2018 Membro de CSU Fullerton, Team S2-G5, Bruce Fall 2018
CSUF-BRUCE-F18S2G5
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 169
