Ir para o conteúdo principal
ASUS K200MA-DS01T Battery Replacement
O que você precisa
  1. ASUS K200MA-DS01T Battery Replacement, Back Panel: passo 1, imagem 1 %32 ASUS K200MA-DS01T Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Battery Replacement: passo 2, imagem 1 %32 ASUS K200MA-DS01T Battery Replacement: passo 2, imagem 2 %32
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Battery Replacement: passo 3, imagem 1 %32
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Battery Replacement: passo 4, imagem 1 %32 ASUS K200MA-DS01T Battery Replacement: passo 4, imagem 2 %32 ASUS K200MA-DS01T Battery Replacement: passo 4, imagem 3 %32
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Battery Replacement, Keyboard: passo 5, imagem 1 %32 ASUS K200MA-DS01T Battery Replacement, Keyboard: passo 5, imagem 2 %32
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Battery Replacement: passo 6, imagem 1 %32 ASUS K200MA-DS01T Battery Replacement: passo 6, imagem 2 %32
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Battery Replacement, Battery: passo 7, imagem 1 %32 ASUS K200MA-DS01T Battery Replacement, Battery: passo 7, imagem 2 %32
    • Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
    • Remove the following screws from the middle and far ends of the battery:
    • Three 4mm Phillips screws using a Phillips #0 screwdriver.
    • The battery will be located closest to the screen.
  8. ASUS K200MA-DS01T Battery Replacement: passo 8, imagem 1 %32 ASUS K200MA-DS01T Battery Replacement: passo 8, imagem 2 %32 ASUS K200MA-DS01T Battery Replacement: passo 8, imagem 3 %32
    • Gripping the wider left section, lift the battery up and away from computer.
Conclusão
Aliyah Malapit
Membro desde: 09/26/18
199 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team S2-G5, Bruce Fall 2018 Membro de CSU Fullerton, Team S2-G5, Bruce Fall 2018
CSUF-BRUCE-F18S2G5
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 341
