Ir para o conteúdo principal
ASUS GL752VW-DH74 Optical Drive Replacement
O que você precisa
  1. ASUS GL752VW-DH74 Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32
    • Begin by putting the needle into the hole in the disk tray.
    I want to point out that in order to do this step you have to remove the screw holding the CD drive in place first. On top of this if the screw is out very light pulling on the drive will remove it. There is no need for a pry tool or a needle to eject it. To make it easier on yourself I would actually do step 5 first and just be done with all the screws before you take out the CD screw (Which, by the way, step 5 is shown with the CD drive still attached and screwed in which can cause confusion and possible damage if not careful/paying attention).
    Stephen Patterson - Responder
  2. ASUS GL752VW-DH74 Optical Drive Replacement: passo 2, imagem 1 %32
    • Use the spudger to help ease out the disk drive.
  3. ASUS GL752VW-DH74 Optical Drive Replacement: passo 3, imagem 1 %32
    • Pull out disk tray entirely.
    I was not able to extract the DVD drive until unscrewing the .8 screw central on the back of the laptop. That one holds the DVD drive.
    Vio Belc - Responder
    You have to also remove the screw securing the DVD drive to the case.
    sgust - Responder
Conclusão
Ralph Lopez
Membro desde: 10/23/17
202 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 Membro de UMass Dartmouth, Team S1-G3, Isaacson Fall 2017
UMASSD-ISAACSON-F17S1G3
Membros da 3
Autoria de 5 guias
Um comentário
Prior to step 1 , there is a screw that needs removed [Middle screw on the back on the side with the DVD player]
William Irons - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 1,302
