Ir para o conteúdo principal
ASUS GL752VW-DH74 Keyboard Replacement
O que você precisa
  1. ASUS GL752VW-DH74 Keyboard  Replacement, Optical Drive: passo 1, imagem 1 %32
    • Begin by putting the needle into the hole in the disk tray.
    I want to point out that in order to do this step you have to remove the screw holding the CD drive in place first. On top of this if the screw is out very light pulling on the drive will remove it. There is no need for a pry tool or a needle to eject it. To make it easier on yourself I would actually do step 5 first and just be done with all the screws before you take out the CD screw (Which, by the way, step 5 is shown with the CD drive still attached and screwed in which can cause confusion and possible damage if not careful/paying attention).
    Stephen Patterson - Responder
  2. ASUS GL752VW-DH74 Keyboard  Replacement: passo 2, imagem 1 %32
    • Use the spudger to help ease out the disk drive.
  3. ASUS GL752VW-DH74 Keyboard  Replacement: passo 3, imagem 1 %32
    • Pull out disk tray entirely.
    I was not able to extract the DVD drive until unscrewing the .8 screw central on the back of the laptop. That one holds the DVD drive.
    Vio Belc - Responder
    You have to also remove the screw securing the DVD drive to the case.
    sgust - Responder
  4. ASUS GL752VW-DH74 Keyboard  Replacement, SSD: passo 4, imagem 1 %32
    • Unscrew both 8mm phillip's head screws that hold on the access gate.
  5. ASUS GL752VW-DH74 Keyboard  Replacement: passo 5, imagem 1 %32
    • Use either the your finger, the screw driver, or a spudger to pop out the gate.
  6. ASUS GL752VW-DH74 Keyboard  Replacement: passo 6, imagem 1 %32
    • From here, you can access the hardrive, motherboard, SSD, and RAM.
  7. ASUS GL752VW-DH74 Keyboard  Replacement: passo 7, imagem 1 %32
    • Remove the 4mm screw holding in the SSD.
    • Note that the screw is holding it down so it will pop up once the screw is removed.
  8. ASUS GL752VW-DH74 Keyboard  Replacement: passo 8, imagem 1 %32
    • Remove SSD from slot.
    for god sake this is ssd not ram
    Elvan Ong - Responder
    I had the same exact reaction
    Macmonster 2 - Responder
  9. ASUS GL752VW-DH74 Keyboard  Replacement, Keyboard: passo 9, imagem 1 %32
    • Start by unplugging the laptop and turning it upside down. There are 3 screws in the disk drive, remove those using a Phillips #0 screwdriver.
  10. ASUS GL752VW-DH74 Keyboard  Replacement: passo 10, imagem 1 %32
    • Remove the medium sized panel attached on the back. Then using your Phillips #0 screwdriver, remove all 8 screws.
    Remove the TWO recessed screws above the RAM and the one screw below and to the right of the large button battery.
    Then you need to remove the SATA Laptop Hard Drive or SSD on the left by removing its 4 screws and gently pulling it all the way left before lifting.
    Kari Hartman - Responder
  11. ASUS GL752VW-DH74 Keyboard  Replacement: passo 11, imagem 1 %32
    • Remove the entire large back panel (outer shell) by removing the screws closer to the outer edge.
  12. ASUS GL752VW-DH74 Keyboard  Replacement: passo 12, imagem 1 %32 ASUS GL752VW-DH74 Keyboard  Replacement: passo 12, imagem 2 %32 ASUS GL752VW-DH74 Keyboard  Replacement: passo 12, imagem 3 %32
    • Use the blue opening tool to gently separate the back panel by loosening it on all sides to ease the outer shell of the laptop until it separates.
  13. ASUS GL752VW-DH74 Keyboard  Replacement: passo 13, imagem 1 %32
    • Gently lift the outer shell up until the white, gold and silver power strips are visible. Proceed by removing the strips from the bottom side of the keyboard. Finish removing the outer shell.
  14. ASUS GL752VW-DH74 Keyboard  Replacement: passo 14, imagem 1 %32
    • Remove the two Phillips #0 screws located on the panel above the white power strip.
    There's actually 4 of them.
    gummielindsays - Responder
  15. ASUS GL752VW-DH74 Keyboard  Replacement: passo 15, imagem 1 %32
    • Gently take off the metal keyboard cover by using the blue opening tool.
    As this cover is plastic welded in place, it isn’t possible to replace the cover without glueing it down?
    Gary Fox - Responder
    You need a soldering gun to do this step. Melt the black pins with a soldering gun!
  16. ASUS GL752VW-DH74 Keyboard  Replacement: passo 16, imagem 1 %32 ASUS GL752VW-DH74 Keyboard  Replacement: passo 16, imagem 2 %32
    • Lift up the keyboard panel and replace it with the new one.
Conclusão
5 outras pessoas executaram este guia.
Ryan Maitland
Membro desde: 10/22/17
188 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 Membro de UMass Dartmouth, Team S1-G3, Isaacson Fall 2017
UMASSD-ISAACSON-F17S1G3
Membros da 3
Autoria de 5 guias
3 comentários
This is an extremely useful tutorial for those who have patience and curious to learn. Excellent job by the authors. Thank you.
Mohan Krishnan - Responder
This guide needs more work. The metal keyboard has small black pins that keep it in place. They will need to be melted by a heating/soldering gun, and then remelted to keep the new keyboard in place.
This guide is incomplete. You will require a soldering pencil to reattach the new keyboard to its metal backing plate and the laptop faceplate. It could also be useful in releasing the old keyboard from the backing plate and faceplate. if you are slow and cautious it will probably take you 90 to 120 minutes to complete. 40 minutes is only if you have done this type of keyboard before.
Also read the comments regarding the access bay screws that need to be removed during disassembly and remember to remove the sata drive as well.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 26
Últimos 30 dias: 64
Duração total: 5,885
