Ir para o conteúdo principal
ASUS F555UA-EH71 Battery Replacement
O que você precisa
  1. ASUS F555UA-EH71 Battery Replacement, Keyboard Panel: passo 1, imagem 1 %32
    • Remove the ten 18 mm screws holding down the outer shell of the laptop using the Phillips #000 screwdriver.
  2. ASUS F555UA-EH71 Battery Replacement: passo 2, imagem 1 %32 ASUS F555UA-EH71 Battery Replacement: passo 2, imagem 2 %32
    • Use your fingers to gently pry open the gap between the silver and black parts of the casing.
    • Separate the keyboard panel from the body of the laptop by wedging the iFixit Opening Tool in between the keyboard panel and the body.
    • The teeth of the casing should make a clicking noise as they’re pulled apart.
  3. ASUS F555UA-EH71 Battery Replacement: passo 3, imagem 1 %32
    • Gently open the casing until the white, silver, and gold power strips are visible. Gently peel the strips from the bottom side of the laptop.
    • Disconnect the two cables connecting the keyboard panel to the laptop.
  4. ASUS F555UA-EH71 Battery Replacement: passo 4, imagem 1 %32
    • Remove the keyboard panel from the laptop.
  5. ASUS F555UA-EH71 Battery Replacement, Battery: passo 5, imagem 1 %32 ASUS F555UA-EH71 Battery Replacement, Battery: passo 5, imagem 2 %32 ASUS F555UA-EH71 Battery Replacement, Battery: passo 5, imagem 3 %32
    • Use the Phillips #000 screwdriver to remove the eight 4 mm screws holding the battery in place.
  6. ASUS F555UA-EH71 Battery Replacement: passo 6, imagem 1 %32 ASUS F555UA-EH71 Battery Replacement: passo 6, imagem 2 %32
    • Carefully remove the battery from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 978
