Ir para o conteúdo principal
ASUS F550 Keyboard Replacement
O que você precisa
  1. ASUS F550 Keyboard Replacement, ASUS F550 HDD/Ram Cover Removal: passo 1, imagem 1 %32 ASUS F550 Keyboard Replacement, ASUS F550 HDD/Ram Cover Removal: passo 1, imagem 2 %32
    • Remove the battery, using release clips.
    • Ensure device has no residual power by attempting boot once battery is removed.
    • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
    • Remove HDD and RAM cover
  2. ASUS F550 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32
    • Remove 7 5mm Phillips screws
  3. ASUS F550 Keyboard Replacement: passo 3, imagem 1 %32 ASUS F550 Keyboard Replacement: passo 3, imagem 2 %32 ASUS F550 Keyboard Replacement: passo 3, imagem 3 %32
    • Flip laptop and open lid. Separate the keyboard plate from the main housing, using a plastic prying tool. Being careful not to damage the LED indicators or other peripheries.
    • Disconnect the LED, trackpad, and keyboard ribbon cables.
    • The keyboard can now be removed
Conclusão
8 outras pessoas executaram este guia.
Ryan
Membro desde: 08/19/15
1.414 Reputação
Autoria de 14 guias
3 comentários
great help in getting to the keyboard. keyboard removal requires breaking all the securing posts , but quite easy.
just make sure there are no little bits left on assembly. also take your time and gently fold back all earth straps and insulators etc and then fold back after keyboard is fitted. didn't have one but maybe a hot glue gun would be useful to just pin a few things down.??
anyway all works well so thankyou.
dave - Responder
with a good prying tool shouldn't break any components, i use steel guitar picks and standard plastic wedge tools to separate the parts, however glad to know this guide helped.
Ryan -
Thanks for the instructions posted above. Very helpful.
New question. Can the basic keyboard itself be replaced without recourse to replacing the surrounding frame. I attach a link to illustrate what I want to do. The link shows the basic keyboard on it’s own without the fruit ans salad around it. Thanks
https://www.ebay.com.au/itm/362389048708
christonic1 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 23
Duração total: 9,313
