Introdução
Are the speakers in your ASUS Eee Pad Transformer no longer producing sound? If so, they need to be replaced. Here is the guide to replace the speaker set. All you need is a Phillips #0 Screwdriver and T5 Torx Screwdriver to remove the screws, a Plastic Opening Tool to remove the plastic border, and tweezers to remove the speakers and connection wire.
O que você precisa
Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
Ferramenta utilizada neste passo:Tweezers$4.99
Use the tweezers to grab onto the speaker and lift gently up until the speaker is removed.
Use your fingers to gently slide the speaker under the orange strip.
Uma outra pessoa concluiu este guia.
