Ir para o conteúdo principal
ASUS Eee PC 1008ha Battery Replacement
O que você precisa
  1. ASUS Eee PC 1008ha Battery Replacement, Battery: passo 1, imagem 1 %32
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. ASUS Eee PC 1008ha Battery Replacement: passo 2, imagem 1 %32 ASUS Eee PC 1008ha Battery Replacement: passo 2, imagem 2 %32 ASUS Eee PC 1008ha Battery Replacement: passo 2, imagem 3 %32
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. ASUS Eee PC 1008ha Battery Replacement: passo 3, imagem 1 %32 ASUS Eee PC 1008ha Battery Replacement: passo 3, imagem 2 %32
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
Conclusão
Uma outra pessoa concluiu este guia.
Alex Powers
Membro desde: 04/17/13
101 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 21-52, Johann Spring 2013 Membro de Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
Membros da 4
Autoria de 11 guias
4 comentários
where could i find compatible batteries?
qforkyu - Responder
Good question! Did you find one?
paulteale -
This guide is misleading. There is no way to do step 1 just from the front. At least I cannot do it and my notebook is already half open due to the swollen battery. Most guides show that you need to disassemble the whole thing.
For instance:
http://forum.notebookreview.com/asus/388...
cis - Responder
Батарея состоит из трёх отдельных Li-ion аккумуляторов, соединённых через плату контроллера. Обычно вздувается один из трёх аккумуляторов. Надо разобрать ваш нетбук, как показано в видео:
https://www.youtube.com/watch?v=-3ipeduI...
Тогда надо её аккуратно выкусить и стараться не проколоть надутую батарею, потому что в ней много неприятного запаха. На её место можно поставить подходящий по толщине аккумулятор с напряжением 3.6 - 3.7V с током до 1000mA (1A) и обязательно соблюдать полярность при установке аккумулятора. Тогда вам будет счастье.
С уважением, устный переводчик синхронист.
Simultaneous Translation - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 32
Duração total: 9,951
