Introdução
Use this guide to replace the Keyboard of your ASUS EEE PC701SD-WHI004X. Be sure to disconnect the laptop from all sources of power before beginning this process. You should follow this guide if a single key is unresponsive, cannot be pressed, or if the entire keyboard is unresponsive.
O que você precisa
Flip the laptop over, you should see two battery tabs.
Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
Push the 3 tabs at the top of the keyboard in and down one at a time using a nylon spudger.
Once the three tabs have been pushed in, gently pry the top of the keyboard until it begins to hinge out of its slot.
Uma outra pessoa concluiu este guia.
