Ir para o conteúdo principal
ASUS E210MA-TB.CL464BK Touchpad Replacement
O que você precisa
  1. ASUS E210MA-TB.CL464BK Touchpad Replacement, Touchpad: passo 1, imagem 1 %32 ASUS E210MA-TB.CL464BK Touchpad Replacement, Touchpad: passo 1, imagem 2 %32 ASUS E210MA-TB.CL464BK Touchpad Replacement, Touchpad: passo 1, imagem 3 %32
    • Place the laptop with the bottom side facing up. Have the front (where the touchpad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 screwdriver.
  2. ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 2, imagem 1 %32
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 3, imagem 1 %32 ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 3, imagem 2 %32 ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 3, imagem 3 %32
    • Remove the speakers as outlined in the speaker replacement guide, summarized below.
    • Remove the four 5mm screws, with a J00 screw driver.
    • Locate and remove the white plug by pulling it towards you.
  4. ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 4, imagem 1 %32 ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 4, imagem 2 %32
    • Remove the usb port as outlined in the usb port replacement guide, summarized below.
    • Remove the four 5mm screws with a J00 screwdriver.
    • You do not *need* to fully unplug and remove the USB port, but at least it is out of the way.
  5. ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 5, imagem 1 %32 ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 5, imagem 2 %32 ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 5, imagem 3 %32
    • Remove the battery as described in the battery replacement guide, summarized below.
    • Remove the five 5mm screws securing the battery with a J00 screwdriver.
    • Unplug and disconnect the tape.
  6. ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 6, imagem 1 %32 ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 6, imagem 2 %32
    • Identify the touchpad at the front of the case.
    • Unplug and remove the tape from the top of the touchpad.
  7. ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 7, imagem 1 %32 ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 7, imagem 2 %32
    • Remove the three 5mm screws from the top of the touchpad with a J00 screwdriver.
  8. ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 8, imagem 1 %32 ASUS E210MA-TB.CL464BK Touchpad Replacement: passo 8, imagem 2 %32
    • Slide out the touchpad from under the metal bracket.pinching the top and sliding it forward and up.
Conclusão
John Hutchins
Membro desde: 02/07/23
763 Reputação
Autoria de 5 guias
Equipe
Gateway, Team 73-6, Gonzalez Spring 2023 Membro de Gateway, Team 73-6, Gonzalez Spring 2023
GCC-GONZALEZ-S23S73G6
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 119
