Ir para o conteúdo principal
ASUS E210MA-TB.CL464BK Speaker Replacement
O que você precisa
  1. ASUS E210MA-TB.CL464BK Speaker Replacement, Speaker: passo 1, imagem 1 %32 ASUS E210MA-TB.CL464BK Speaker Replacement, Speaker: passo 1, imagem 2 %32 ASUS E210MA-TB.CL464BK Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Place the laptop with the bottom side facing up. Have the front(where the mousepad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a J00 JIS head screw driver
  2. ASUS E210MA-TB.CL464BK Speaker Replacement: passo 2, imagem 1 %32
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK Speaker Replacement: passo 3, imagem 1 %32 ASUS E210MA-TB.CL464BK Speaker Replacement: passo 3, imagem 2 %32 ASUS E210MA-TB.CL464BK Speaker Replacement: passo 3, imagem 3 %32
    • Remove the four 5mm screws on the speakers.
    • Pop out speakers gently.
  4. ASUS E210MA-TB.CL464BK Speaker Replacement: passo 4, imagem 1 %32
    • Locate the white plug, it should be above the right speaker.
    • Remove the white plug by pulling it towards you.
  5. ASUS E210MA-TB.CL464BK Speaker Replacement: passo 5, imagem 1 %32 ASUS E210MA-TB.CL464BK Speaker Replacement: passo 5, imagem 2 %32
    • Carefully remove the speakers.
Conclusão
John Hutchins
Membro desde: 02/07/23
763 Reputação
Autoria de 5 guias
Equipe
Gateway, Team 73-6, Gonzalez Spring 2023 Membro de Gateway, Team 73-6, Gonzalez Spring 2023
GCC-GONZALEZ-S23S73G6
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 135
