Ir para o conteúdo principal
ASUS E210MA-TB.CL464BK Battery Replacement
O que você precisa
  1. ASUS E210MA-TB.CL464BK Battery Replacement, Battery: passo 1, imagem 1 %32 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: passo 1, imagem 2 %32 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: passo 1, imagem 3 %32
    • Place the laptop with the bottom side facing up. Have the front (where the mousepad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 JIS screwdriver.
  2. ASUS E210MA-TB.CL464BK Battery Replacement: passo 2, imagem 1 %32
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK Battery Replacement: passo 3, imagem 1 %32 ASUS E210MA-TB.CL464BK Battery Replacement: passo 3, imagem 2 %32
    • Remove the 4 mm screws around the USB port.
  4. ASUS E210MA-TB.CL464BK Battery Replacement: passo 4, imagem 1 %32 ASUS E210MA-TB.CL464BK Battery Replacement: passo 4, imagem 2 %32
    • Remove the 3 mm screws around the battery.
    • Carefully lift up the USB port and set it to the side.
  5. ASUS E210MA-TB.CL464BK Battery Replacement: passo 5, imagem 1 %32 ASUS E210MA-TB.CL464BK Battery Replacement: passo 5, imagem 2 %32
    • Unplug the connection between the motherboard and the battery by pulling towards the speaker side.
    • Repeat the same process to remove the blue tape on the second picture.
  6. ASUS E210MA-TB.CL464BK Battery Replacement: passo 6, imagem 1 %32
    • Lift up and remove the battery.
Conclusão
John Hutchins
Membro desde: 02/07/23
763 Reputação
Autoria de 5 guias
Equipe
Gateway, Team 73-6, Gonzalez Spring 2023 Membro de Gateway, Team 73-6, Gonzalez Spring 2023
GCC-GONZALEZ-S23S73G6
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 41
Duração total: 490
