Ir para o conteúdo principal
ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement
O que você precisa
  1. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement, Keyboard & Trackpad Assembly: passo 1, imagem 1 %32
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: passo 2, imagem 1 %32 ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: passo 2, imagem 2 %32
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom:
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: passo 3, imagem 1 %32 ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: passo 3, imagem 2 %32 ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: passo 3, imagem 3 %32
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: passo 4, imagem 1 %32 ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: passo 4, imagem 2 %32 ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: passo 4, imagem 3 %32
    • Gently detach connecting cables.
    • Carefully flip up the large black tab.
    • Carefully flip up small white tab.
    • Remove the corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
Conclusão
Gina Altimari
Membro desde: 09/28/17
401 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S2-G5, Passmore Fall 2017 Membro de USF Tampa, Team S2-G5, Passmore Fall 2017
USFT-PASSMORE-F17S2G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 166
