Ir para o conteúdo principal
ASUS Chromebook C200MA DS01 USB Board Replacement
O que você precisa
  1. ASUS Chromebook C200MA DS01 USB Board Replacement, Back Panel: passo 1, imagem 1 %32
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 USB Board Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 USB Board Replacement: passo 3, imagem 1 %32
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 USB Board Replacement, Battery Connection: passo 4, imagem 1 %32 ASUS Chromebook C200MA DS01 USB Board Replacement, Battery Connection: passo 4, imagem 2 %32 ASUS Chromebook C200MA DS01 USB Board Replacement, Battery Connection: passo 4, imagem 3 %32
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 USB Board Replacement, USB Board: passo 5, imagem 1 %32 ASUS Chromebook C200MA DS01 USB Board Replacement, USB Board: passo 5, imagem 2 %32 ASUS Chromebook C200MA DS01 USB Board Replacement, USB Board: passo 5, imagem 3 %32
    • Disconnect the USB board ZIF (zero insertion force) connectors which connect the motherboard to the USB board in the upper left.
    • Flip the ZIF retaining flaps up using a plastic opening tool or your fingers.
    • Pull gently on the ribbon cable to disconnect it from the sockets.
  6. ASUS Chromebook C200MA DS01 USB Board Replacement: passo 6, imagem 1 %32
    • Remove the three 5.77 mm Phillips screws on the USB board.
    • Remove the two 4.77 mm Phillips screws from the hinge.
  7. ASUS Chromebook C200MA DS01 USB Board Replacement: passo 7, imagem 1 %32
    • Use a plastic opening tool to lift the hinge from the Chromebook.
  8. ASUS Chromebook C200MA DS01 USB Board Replacement: passo 8, imagem 1 %32
    • Gently lift the USB board from the Chromebook.
Conclusão
Christopher Lim
Membro desde: 04/26/17
779 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S23-G4, Livingston Spring 2017 Membro de Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
Membros da 4
Autoria de 19 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 547
