Ir para o conteúdo principal
ASUS Chromebook C200MA DS01 Motherboard Replacement
O que você precisa
  1. ASUS Chromebook C200MA DS01 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Motherboard Replacement, Battery Connection: passo 4, imagem 1 %32 ASUS Chromebook C200MA DS01 Motherboard Replacement, Battery Connection: passo 4, imagem 2 %32 ASUS Chromebook C200MA DS01 Motherboard Replacement, Battery Connection: passo 4, imagem 3 %32
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Disconnect the USB board ZIF (zero insertion force) connector located towards the bottom left of the motherboard.
    • Flip the ZIF connector retaining flap up using either a spudger or your fingers.
    • Pull gently on the ribbon cable to disconnect it from the motherboard.
  6. ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 6, imagem 1 %32 ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 6, imagem 2 %32 ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 6, imagem 3 %32
    • Disconnect the large keyboard and small touchpad ZIF connectors, both located in the middle of the bottom edge of the motherboard.
    • Flip both ZIF retaining flaps up using either a spudger or your fingers.
    • Gently pull on each ribbon cable to disconnect them from the motherboard.
  7. ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 7, imagem 1 %32 ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 7, imagem 2 %32
    • Disconnect the speaker's black bundled cable connector (the cable is white, black and red).
    • Pinch the black bundled cable connector between your thumb and pointer finger and pull.
  8. ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 8, imagem 1 %32 ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 8, imagem 2 %32 ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 8, imagem 3 %32
    • Disconnect the screen cable connector located towards the top right of the motherboard.
    • Using a spudger, gently pry up the sides of the connector.
    • Pull off the connector with your hands.
  9. ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 9, imagem 1 %32 ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 9, imagem 2 %32
    • Disconnect the black and white antenna cable connectors for the WiFi card. The connectors look like small buttons on the ends of colored wires.
    • Gently pry the cable connectors off with your fingers or a spudger.
    • These connections are button-like and will have a little resistance when removing.
  10. ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 10, imagem 1 %32
    • Remove the eight Phillips #0 4.7 mm screws.
    • Remove the Phillips #0 3.7 mm screw.
    • Remove the Phillips #0 2.8 mm screw.
  11. ASUS Chromebook C200MA DS01 Motherboard Replacement: passo 11, imagem 1 %32
    • Lift the motherboard from the Chromebook.
Conclusão
Christopher Lim
Membro desde: 04/26/17
779 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S23-G4, Livingston Spring 2017 Membro de Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
Membros da 4
Autoria de 19 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 17
Duração total: 2,056
