Ir para o conteúdo principal
ASUS Chromebook C200MA DS01 Battery Replacement
O que você precisa
  1. ASUS Chromebook C200MA DS01 Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Battery Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Battery Replacement: passo 3, imagem 1 %32
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Battery Replacement, Battery Connection: passo 4, imagem 1 %32 ASUS Chromebook C200MA DS01 Battery Replacement, Battery Connection: passo 4, imagem 2 %32 ASUS Chromebook C200MA DS01 Battery Replacement, Battery Connection: passo 4, imagem 3 %32
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Battery Replacement, Battery: passo 5, imagem 1 %32 ASUS Chromebook C200MA DS01 Battery Replacement, Battery: passo 5, imagem 2 %32
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Battery Replacement: passo 6, imagem 1 %32
    • Pull out the battery.
Conclusão
Christopher Lim
Membro desde: 04/26/17
779 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S23-G4, Livingston Spring 2017 Membro de Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
Membros da 4
Autoria de 19 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 65
Duração total: 13,386
