Ir para o conteúdo principal
ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement
O que você precisa
  1. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Lower Case: passo 1, imagem 1 %32
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: passo 3, imagem 1 %32
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: passo 4, imagem 1 %32
    • Use the iFixit opening tool to remove the back of the laptop.
  5. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: passo 5, imagem 1 %32
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
  6. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Trackpad: passo 6, imagem 1 %32 ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Trackpad: passo 6, imagem 2 %32
    • Grip the keyboard and carefully pull it off the device.
  7. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: passo 7, imagem 1 %32 ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: passo 7, imagem 2 %32
    • On the back of the keyboard assembly, use the tweezers to pull the white cable from the track pad.
  8. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: passo 8, imagem 1 %32
    • Remove the three 1 mm screws from the track pad using the JIS 00 screwdriver.
  9. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: passo 9, imagem 1 %32 ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: passo 9, imagem 2 %32
    • Grip the track pad with the tweezers and slide it up and out of the keyboard assembly.
Conclusão
Lauren Schirle
Membro desde: 01/24/19
205 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S19-G4, White Winter 2019 Membro de Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 338
