Ir para o conteúdo principal
ASUS Chromebook C100PA-RBRKT07 Battery Replacement
O que você precisa
  1. ASUS Chromebook C100PA-RBRKT07 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 3, imagem 1 %32
    • Use the T5 screwdriver to remove the 6 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 4, imagem 1 %32
    • Use the iFixit opening tool to pry the backing of the device off.
  5. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 5, imagem 1 %32
    • Use the tweezers to separate the cables from the motherboard.
    • You need to reach inside and peel some tape to disconnect the wire.
  6. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 6, imagem 1 %32
    • Use the JIS1 screwdriver to remove the four 2.1 mm screws around the audio cards.
  7. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 7, imagem 1 %32 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 7, imagem 2 %32
    • Gently disconnect the audio cards, exposing the battery.
  8. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 8, imagem 1 %32
    • Use the J00 screwdriver to remove the three 1.7 mm battery screws.
  9. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 9, imagem 1 %32 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 9, imagem 2 %32 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 9, imagem 3 %32
    • Grip the battery and remove it from the device.
    • Remove the battery cable out of the motherboard by lifting the battery cables.
Conclusão
Tiffany Foo
Membro desde: 01/24/19
289 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S19-G4, White Winter 2019 Membro de Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 360
