Ir para o conteúdo principal
ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement
O que você precisa
  1. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement, Lower Case: passo 1, imagem 1 %32
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: passo 4, imagem 1 %32
    • Use the iFixit opening tool to remove the back of the laptop.
  5. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: passo 5, imagem 1 %32
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
  6. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement, Audio Ports: passo 6, imagem 1 %32
    • Remove the four 3mm J1 screws attached to the audio cards.
  7. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: passo 7, imagem 1 %32 ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: passo 7, imagem 2 %32
    • Lift and remove the audio cards.
    • Separate the wires from the motherboard.
Conclusão
Tomas Martinez
Membro desde: 01/24/19
185 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S19-G4, White Winter 2019 Membro de Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 131
