Ir para o conteúdo principal
Introdução
This is the first step taken in order to fix many of the parts in this device. Be careful to not strip any of the screws.
Peças
Nenhum componente especificado.
  1. Begin by removing the condensation catcher to expose the screw. Pinch the condensation catcher from both sides and pull. Begin by removing the condensation catcher to expose the screw. Pinch the condensation catcher from both sides and pull.
    • Begin by removing the condensation catcher to expose the screw. Pinch the condensation catcher from both sides and pull.
  2. Remove the screw that was behind the condensation catcher using a Phillips head screwdriver, size PH2.
    • Remove the screw that was behind the condensation catcher using a Phillips head screwdriver, size PH2.
  3. Remove the piece that was held by the screw by pulling out from the top, then pulling up. This will expose the hinges for the lid. Remove the piece that was held by the screw by pulling out from the top, then pulling up. This will expose the hinges for the lid.
    • Remove the piece that was held by the screw by pulling out from the top, then pulling up. This will expose the hinges for the lid.
  4. To remove the hinges, rotate the bottom of the rod upwards, then push inwards to pull them out. Repeat the process for both sides. This will allow the lid to be removed. To remove the hinges, rotate the bottom of the rod upwards, then push inwards to pull them out. Repeat the process for both sides. This will allow the lid to be removed. To remove the hinges, rotate the bottom of the rod upwards, then push inwards to pull them out. Repeat the process for both sides. This will allow the lid to be removed.
    • To remove the hinges, rotate the bottom of the rod upwards, then push inwards to pull them out. Repeat the process for both sides. This will allow the lid to be removed.
Conclusão
Uma outra pessoa concluiu este guia.
Brandon Nieves
Membro desde: 04/09/2015
956 Reputação
8 Guias de autoria
Equipe
USF Tampa, Team 2-3, Sullivan Fall 2015 Membro de USF Tampa, Team 2-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G3
3 Membros
8 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 882
