Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
Flip the device right side up.
Gently slide the casing upwards and off the hard drive.
Flip device upside down again.
Gently pry the bottom gray casing away from the device.
Rotate so the back of the device is facing you.
Gently pry the back casing away.
When the back casing is removed, the fan will become loose.
Find the conjoined ID cable wires that are colored black, orange, and yellow.
Lift white portion of cable wires to disconnect it.
Using the spudger, depress the pressure holders at all four corners of the fan.
Take out the fan and its cords, by pulling it outward from its cavity within the device.
Uma outra pessoa concluiu este guia.
