Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If your camera has become scratched or broken, then this guide will help you take apart your tablet in order to access the camera. We will show you how to disassemble your tablet and then how to locate the camera in order to replace it.
O que você precisa
To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
Remove the black electrical tape covering the motherboard components along with the black cloth tape covering the camera itself.
Be careful when removing the black cloth tape from the camera on the top left corner of the tablet. The tape will likely stick and pull the camera with it.
