Ir para o conteúdo principal
APEX AP-GS918 Battery Replacement
O que você precisa
  1. APEX AP-GS918 Battery Replacement, Power/Volume Button: passo 1, imagem 1 %32 APEX AP-GS918 Battery Replacement, Power/Volume Button: passo 1, imagem 2 %32 APEX AP-GS918 Battery Replacement, Power/Volume Button: passo 1, imagem 3 %32
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. APEX AP-GS918 Battery Replacement: passo 2, imagem 1 %32 APEX AP-GS918 Battery Replacement: passo 2, imagem 2 %32 APEX AP-GS918 Battery Replacement: passo 2, imagem 3 %32
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. APEX AP-GS918 Battery Replacement: passo 3, imagem 1 %32 APEX AP-GS918 Battery Replacement: passo 3, imagem 2 %32
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
  4. APEX AP-GS918 Battery Replacement, Battery: passo 4, imagem 1 %32 APEX AP-GS918 Battery Replacement, Battery: passo 4, imagem 2 %32
    • Begin removing the black tape covering the motherboard inside the tablet.
  5. APEX AP-GS918 Battery Replacement: passo 5, imagem 1 %32
    • You will need to desolder the two contact points that connect the battery to the mother board.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
  6. APEX AP-GS918 Battery Replacement: passo 6, imagem 1 %32 APEX AP-GS918 Battery Replacement: passo 6, imagem 2 %32
    • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
    • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
Conclusão
Megan Lozicki
Membro desde: 02/19/15
413 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 9-1, Leahy Winter 2015 Membro de USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
Membros da 3
Autoria de 9 guias
Um comentário
bien consejo, creo que es sencillo por todos para seguin estos pasos
harkhoscole - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 483
