Introdução
We will show you how to disassemble your tablet in order to access the battery. This replacement guide is helpful if you feel that your battery is faulty and no longer holding charge. Therefore, you need to replace it.
O que você precisa
To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
Um comentário
bien consejo, creo que es sencillo por todos para seguin estos pasos
