Ir para o conteúdo principal
AEG Electrolux FM72 Disassembly for cleaning
O que você precisa
  1. AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: passo 1, imagem 1 %32 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: passo 1, imagem 2 %32 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: passo 1, imagem 3 %32
    • Open the lid by pressing the grey button and lifting it away.
    • Clean each of the plastic parts with soap and water, and then leave them out to dry.
  2. AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: passo 2, imagem 1 %32 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: passo 2, imagem 2 %32 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: passo 2, imagem 3 %32
    • Follow these steps to open the electronic casing.
    • Remove the four screws as shown in picture two.
    • A long Phillips screwdriver is needed for step two.
    • Remove the fifth screw at the bottom as shown in picture three.
  3. AEG Electrolux FM72 Disassembly for cleaning: passo 3, imagem 1 %32 AEG Electrolux FM72 Disassembly for cleaning: passo 3, imagem 2 %32 AEG Electrolux FM72 Disassembly for cleaning: passo 3, imagem 3 %32
    • Gently pry the device open, using an iSesamo opener.
    • Now the I/O button can be removed.
    • Completely replacing this entire part requires desoldering wire connections.
  4. AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: passo 4, imagem 1 %32 AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: passo 4, imagem 2 %32
    • Now the electronic components can be cleaned using an air compressor.
    • In picture one, you can see the PCBs. Under the PCB, you'll see blue batteries. These are 2 x 3 AA rechargeable batteries .
    • If the dust bag needs to be replaced, remove its securing screws.
Conclusão
3 outras pessoas executaram este guia.
Kevin D
Membro desde: 05/02/14
7.294 Reputação
Autoria de 21 guias
3 comentários
Hello
How can i repair the electric wire on this device please ?
Heloise - Responder
Hallo
Which electric wire do you mean? Can you send in a picture? Does it need soldering?
Kind regards
Kevin
Kevin D - Responder
How can I disassemble the motor parts for cleaning?
wongkapo0611 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 12
Últimos 30 dias: 35
Duração total: 6,503
