Introdução
The video screen ribbon cable is a part of the device used for transferring encrypted data between the video screen and the motherboard. Consider checking this guide before moving ahead to video screen replacement, since you might just have a disconnected or faulty ribbon connector.
O que você precisa
Press upwards with your index finger on the 4P4C connector as shown in the image.
Pull the connector gently out of its socket.
Flip the main body of the video phone so that the bottom is facing up.
Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
Note that the video screen is no longer attached to the top case, place in on a flat surface.
Gently lift of the silver casing.
Uma outra pessoa concluiu este guia.
