Introdução
The video screen displays video sent from a device you have connected to (i.e. another Iris WG4K). If your screen is glitched, foggy, or does not display any video, your video screen may be faulty and may need replacing. This guide is here to help.
O que você precisa
Press upwards with your index finger on the 4P4C connector as shown in the image.
Pull the connector gently out of its socket.
Flip the main body of the video phone so that the bottom is facing up.
Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
Note that the video screen is no longer attached to the top case, place in on a flat surface.
Gently lift of the silver casing.
