Ir para o conteúdo principal
ACN Iris WG4K Key Pad Replacement
O que você precisa
  1. ACN Iris WG4K Key Pad Replacement, Handset: passo 1, imagem 1 %32 ACN Iris WG4K Key Pad Replacement, Handset: passo 1, imagem 2 %32
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Key Pad Replacement, Lower Case: passo 2, imagem 1 %32
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Key Pad Replacement: passo 3, imagem 1 %32 ACN Iris WG4K Key Pad Replacement: passo 3, imagem 2 %32
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Key Pad Replacement: passo 4, imagem 1 %32 ACN Iris WG4K Key Pad Replacement: passo 4, imagem 2 %32 ACN Iris WG4K Key Pad Replacement: passo 4, imagem 3 %32
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Key Pad Replacement: passo 5, imagem 1 %32 ACN Iris WG4K Key Pad Replacement: passo 5, imagem 2 %32
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Key Pad Replacement: passo 6, imagem 1 %32
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Key Pad Replacement, Key Pad: passo 7, imagem 1 %32
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws 6 mm highlighted by the red circles.
  8. ACN Iris WG4K Key Pad Replacement: passo 8, imagem 1 %32
    • Gently lift up on the top case to separate it from the keypad/speaker panel.
  9. ACN Iris WG4K Key Pad Replacement: passo 9, imagem 1 %32 ACN Iris WG4K Key Pad Replacement: passo 9, imagem 2 %32
    • Disconnect the two white 2-pin JST connectors from the keypad/speaker circuit board by tugging gently until they are released.
  10. ACN Iris WG4K Key Pad Replacement: passo 10, imagem 1 %32
    • Use the Philips screw driver to remove the four Phillips head screws 6 mm highlighted by the red circles.
Conclusão
Uma outra pessoa concluiu este guia.
Itze Kenney
Membro desde: 02/14/17
1.066 Reputação
Autoria de 9 guias
Equipe
USF Tampa, Team 20-4, Remmell Spring 2017 Membro de USF Tampa, Team 20-4, Remmell Spring 2017
USFT-REMMELL-S17S20G4
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 178
