Ir para o conteúdo principal
ACER Aspire V5-571P-6609 RAM Replacement
O que você precisa
  1. ACER Aspire V5-571P-6609 RAM Replacement, RAM: passo 1, imagem 1 %32 ACER Aspire V5-571P-6609 RAM Replacement, RAM: passo 1, imagem 2 %32 ACER Aspire V5-571P-6609 RAM Replacement, RAM: passo 1, imagem 3 %32
    • Make sure you completely power off the device before proceeding.
    • Turn over the device to display the back cover and remove the two marked Phillips #0 screws.
  2. ACER Aspire V5-571P-6609 RAM Replacement: passo 2, imagem 1 %32 ACER Aspire V5-571P-6609 RAM Replacement: passo 2, imagem 2 %32 ACER Aspire V5-571P-6609 RAM Replacement: passo 2, imagem 3 %32
    • Once the screws have been removed, utilize a jimmy tool to pry open the back cover. Carefully lift the cover and set it aside for now.
  3. ACER Aspire V5-571P-6609 RAM Replacement: passo 3, imagem 1 %32 ACER Aspire V5-571P-6609 RAM Replacement: passo 3, imagem 2 %32 ACER Aspire V5-571P-6609 RAM Replacement: passo 3, imagem 3 %32
    • With two fingers, push the latches holding the DIMM to the sides.
    • The DIMM will tilt upward once it is released from the slot.
    • Carefully secure the DIMM and remove it.
  4. ACER Aspire V5-571P-6609 RAM Replacement: passo 4, imagem 1 %32 ACER Aspire V5-571P-6609 RAM Replacement: passo 4, imagem 2 %32 ACER Aspire V5-571P-6609 RAM Replacement: passo 4, imagem 3 %32
    • Repeat the same process from the previous step for the second slot.
  5. ACER Aspire V5-571P-6609 RAM Replacement: passo 5, imagem 1 %32 ACER Aspire V5-571P-6609 RAM Replacement: passo 5, imagem 2 %32
    • Insert the replacement DIMM into the slot.
    • Once inserted, push the DIMM down gently until it snaps into place.
  6. ACER Aspire V5-571P-6609 RAM Replacement: passo 6, imagem 1 %32 ACER Aspire V5-571P-6609 RAM Replacement: passo 6, imagem 2 %32 ACER Aspire V5-571P-6609 RAM Replacement: passo 6, imagem 3 %32
    • Place the cover back on.
    • Insert the screws back into place with a screwdriver.
Conclusão
To reassemble your device, follow these instructions in reverse order with new RAM cards.
Ernesto Pacheco
Membro desde: 10/25/22
277 Reputação
Autoria de 2 guias
Equipe
Gateway, Team 1-1, Pee Fall 2022 Membro de Gateway, Team 1-1, Pee Fall 2022
GCC-PEE-F22S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 208
