Introdução
Using this guide you will be able to replace or remove the RAM from your laptop.
O que você precisa
Flip your laptop over so the back panel is facing upwards.
Locate the lock switch below the battery.
Unscrew the one 2.5 x 8mm Phillips #0 screw from the bottom panel as designated in the image.
Uma outra pessoa concluiu este guia.
